How to Improve Line Speeds and Increase Throughput with AI-based Machine Vision
In this webinar, you’ll learn about using AI in machine vision to improve line speeds and increase throughput.
In partnership with
Cognex
Webinar Overview
High speed, high resolution, high flexibility. The In-Sight 3800 has it all. This advanced vision system provides a powerful, yet easy-to-use, solution for automated inspections. Embedded with a full set of robust rule-based tools and innovative edge learning technology, In-Sight 3800 solves a wide range of manufacturing applications, from defect detection and assembly verification to character reading and more. In this webinar learn how the In-Sight 3800 enables you to:
- Run more inspections in less time – Maximize throughput with high-speed processing and quick setup
- Improve the accuracy of your results – Generate high-contrast, high-resolution images that detect even the most subtle defects
- Seamlessly scale your solution – Solve jobs, from easy to complex, using a common software platform
Error
