Festo’s New DHPL Parallel Gripper Offers Versatile EoAT Solution
Festo announces the introduction of a new line of long-stroke parallel DHPL grippers, offering high torque and load in a compact, lightweight, and affordable product line.
A global leader in electromechanical and pneumatic systems, Festo has recently added to its line of gripping products, the new DHPL series. The new generation of long-stroke DHPL grippers offer a compact size with impressive features, designed to handle applications that require high loads and torque.
Festo’s new DHPL long-stroke gripper. Image used courtesy of Festo
Key Features of Festo’s DHPL Gripper
For consistent and precise gripping, the new DHPL gripper is equipped with rack and pinion designs and three guide rods that give the gripper an impressive repeat accuracy of as little as 0.03 mm. Designed for high load and torque applications, the gripper offers a force rating of between 40 and 750 N, rated for use in pressure systems of up to 116 psi, making it adaptable to a wide range of industrial needs.
Designed from anodized cast aluminum alloy, the parallel grippers come in a lightweight and compact design, making them suitable for modern machines where power conservation is a rising priority. When it comes to ongoing upkeep of the moving parts, the new gripper comes fully sealed with a lifetime lubrication that needs no maintenance. Featuring a substantial jaw stroke range, from 20 to 200 mm, the DHPL gripper is flexible in accommodating diverse gripping needs for different industrial applications.
Flexible in Mounting and Sensor Placement
To allow seamless integration into existing systems, the DHPL offers end users and machine builders flexible sensor placement and mounting options. For precise mounting, the grippers are equipped with positioning pin holes that also simplify replacement and integration. The grippers have jaw interfaces in which fingers and brackets can be added by the end user, suitable for either inner or outer gripping (meaning gripping the part when closed or gripping when extended).
Pneumatic End-Position Cushioning
As a standard feature, Festo's new long-stroke parallel gripper comes with pneumatic end-position cushioning for smoother performance and longer life when operated at the extreme ends of the stroke. This cushioning offers adjustability, allowing optimization based on the mass and the speed needed for the specific application.
Competitive Pricing and Application
The new long-stroke parallel gripper offers a more accessible gripping solution in a wider application range with its competitive pricing strategy. This gripper’s versatility in design makes it a targeted solution for use in gripping parts, stacking boxes, keeping bags open during manufacturing processes, and handling shaped parts.
The longer-stroke models of Festo’s new DHPL catalog. Image used courtesy of Festo
Festo’s Integrated Solutions
The DHPL forms part of Festo's ecosystem that ensures ease of integration with seamless connectivity with other systems and components for increased efficiency while further reducing engineering overhead. With this extended product lineup, customers can expect faster time to market making easy integration of gripping solutions in their industrial processes.
With the constant advancement of gripper technology, the implementation of advanced gripper solutions is also increasing to cater to changing industrial needs. Festo's DHPL long-stroke parallel gripper's advanced features, high performance, interchangeability with competitive grippers, and affordability make it a top market choice for those seeking advanced gripping solutions.
