HMS Networks Enables Raspberry Pi 5-Compatible CompactCom Interface
To ensure compatibility with the new Raspberry Pi 5 computer board, HMS Networks has updated the CompactCom system, providing easy expansion to the Pi’s networking capability.
Last year, HMS Networks introduced the Raspberry Pi adapter board, offering manufacturers an easy way to test and evaluate the Anybus CompactCom. This ready-made communication interface connects devices to various industrial networks. HMS Networks has ensured that the AnyBus CompactCom Raspberry Pi Adapter Board will be compatible with the latest Raspberry Pi 5 release which features the new RP1 I/O controller.
Anybus CompactCom from HMS Networks is now compatible with Raspberry Pi 5. Image used courtesy of HMS Networks
What is CompactCom?
The Anybus CompactCom is a family of communication modules developed by HMS Networks. The modules are designed to enable industrial devices to communicate over different networks. They serve as compact and interchangeable communication interfaces that can be integrated into various types of industrial equipment such as robots, drives, and sensors.
HMS Networks has recently made its CompactCom compatible with the new Rasberry Pi 5. Anybus CompactCom modules will provide a convenient solution for OEMs (original equipment manufacturers) looking to add network connectivity to their industrial devices, facilitating communication across various protocols.
CompactCom Network Expansions Now Compatible with Raspberry Pi 5
The original release of the Rasberry Pi adapter board created significant interest from CompactCom users, and HMS Networks wants to expand on that interest by adding Raspberry Pi 5 compatibility. The latest version of the Host Application Example Code (HAEC) can be used with all Raspberry Pi models that incorporate the 40-pin GPIO header. The HAEC is free to download, giving users a communication adapter board for whatever their needs may be.
CompactCom represents a quick and simple way for users to create their industrial device network. This single module grants development access to many different networks including:
- PROFINET
- EtherCAT
- BACnet
- PROFIBUS
- CC-Link
- Ethernet/IP
- DeviceNet
The CompactCom add-on gives additional network functionality, such as Ethernet/IP, to the Raspberry Pi platform. Image used courtesy of HMS Networks
Users gain access by simply connecting to the module containing their chosen network port. The Anybus NP40 network processor is able to funnel all networking needs, protocol stacks, and API towards the microcontroller. The CompactCom then exchanges information with a PLC and any other nodes in the network.
The CompactCom comes in a variety of form factors to suit individual needs. The M40 Module is an all-in-one module that is flexible enough for any network and provides the fastest time to market. Another option is the B40 Brick which encompasses a PCB piggyback board for free connector choice and all Ethernet variants in one board; it is the most economical solution.
Universal Network Integration
HMS Networks has made CompactCom compatible with the latest Raspberry Pi 5, giving users access to a system fully certified by all network associations. This device allows users access to nearly all networks and fieldbuses with a single module. HMS Networks already has 7 million devices installed, with the latest changes allowing for further integration of the system into the user's industrial networks.
