OMRON Launches i4 Series SCARA Robots to Automate Assembly and Transportation Processes
OMRON announced a new series of industrial SCARA robots with high precision and high-speed capabilities.
OMRON developed the i4 series SCARA machines to automate high-speed and high-precision assembly, as well as transportation processes.
The i4 Series SCARA Robots
The new i4 series consists of two separate robots—a larger i4H model designed for high-performance tasks and a compact i4L machine developed for lightweight applications.
Video courtesy of OMRON.
Both models are compatible with OMRON’s robot-hands, allowing engineers to select different end effectors based on the task required and consequently automate it.
The i4H and i4L series feature 15kg and 5kg maximum payload capacity, respectively.
The former has 650mm, 750mm, and 850mm reach options, with the latter supporting 350mm, 450mm, and 550mm reach options. The i4L series also features a standard 180mm quill, with 350mm long quill available for 550mm reach length models.
Diagnostics in the i4H model is shown via the multi-colored LED lighting ring indicators and display, while the i4L series offers a multi-color LED light dome.
LED indicators on the i4 series SCARA robots. Image courtesy of OMRON.
Finally, the i4H model comes with an IP65 rating, and in ESD and USDA options.
Payload and Applications
According to OMRON, the need for automated robots is sharply rising worldwide due to the pandemic effects and general labor shortages.
SCARA robots could help tackle this issue thanks to their easy installation and high-speed work environment automation capabilities. Still, compatibility issues between these machines and peripheral devices can often hinder the adaptation process.
Robots’ end-effector mounts may also become heavy during the execution of complicated tasks, thus exceeding the device’s transportable weight.
The i4 series aims at circumventing these issues by integrating and controlling the end effector and peripheral devices at high speed and with high precision via a Robotic Integrated Controller. Supporting a 15kg payload and incorporating EtherCAT communication inside the robot arm, the machines can then deploy in cooperation with various handling and OMRON's Robotic Integrated Controllers.
A robot from the i4 Series SCARA. Image courtesy of OMRON.
Among these, the i4 series is compatible with a heavy-end effector, enabling the machines to perform assembly and transportation processes that could not be automated with SCARA robots in the past.
The machines also feature embedded highly visible displays and LED lights to enable easy operation and fault status identification.
Designing Flexible Machines
To minimize the robots’ footprint, both control box and cables are fully integrated into a stylized base. The i4 series SCARA robots also facilitate programming efforts thanks to the "Sysmac Studio" integrated PLC programming software.
The program allows for the simulation of equipment performance at an early stage of design, thus enabling electrical designers to program equipment accordingly. The new machines’ software capabilities can also reduce downtime thanks to their dedicated maintenance features.
The i4L series offers Ethernet and EtherCAT connectivity, enabling compatibility with traditional simple controls, as well as adaptations to a broader application range.
These robots can be mounted on a horizontal surface via a table mount or a vertical surface via wall mount without the need for additional adaptors or brackets.
