Parker Hannifin Announces PAC Motion Controller and Modules
Hydraulic component leader Parker Hannifin recently announced a new PAC motion controller and module series with web-based visualization for instant remote monitoring of up to 40 motion axes.
Hydraulic control for motion has existed since before the days of electricity. The force of water was a primary driver for liquid and steam applications, with the liquid systems in modern times being replaced by more viscous, temperature-resistant oils and synthetic hydraulic fluids.
To control these fluid motion systems, Parker Hannifin is a well-recognized leader throughout the field of fluids. From pumps to generate pressure, hoses, fittings, and valves to transport the fluids, to the actuators fixed to the mobile loads.
Parker Hannifin PAC multi-axis electrohydraulic motion control system. Image used courtesy of Parker
Recently, Parker Hannifin announced a new product series for precise feedback-based control of hydraulic motion. This Parker Automation Controller (PAC) series includes both controllers and axis modules.
PAC120 Controller
The controller module includes many industry-stadard communication and capability options, much like a modern PLC or other motion controller. The primary communication interface is EtherCAT, with a secondary isolated Fieldbus port providing access to either a second EtherCAT network, Ethernet/IP (supporting Modbus TCP), or PROFINET I/O depending on the specific model.
The DIN rail mounted controller includes an SD card slot for data logging applications and a USB socket for one local PC programming/monitoring connection. All programming, both initial configuration and logic programs, is performed in the IEC 61131-compliant CODESYS V3 environment, with a web-based interface for integration with remote monitoring and diagnostic dashboards and connection with web HMI panels.
Parker PAC120 motion controller. Image used courtesy of Parker
The maximum number of hydraulic axes supported by the PAC120 controller is 40, but the PACHC axis modules must be installed and configured separately to achieve such capability.
PACHC Motion Axis Modules
The PACHC motion axis module is used for 1 or 2 unique axes (most likely hydraulic actuators). Feedback in the form of 2x analog inputs, available for either voltage or current modes.
Sensors can be added to these inputs for precise control under the following conditions:
- Position feedback is achieved with an analog linear position sensor (such as a high-quality linear potentiometer).
- Force sensing measures the direct physical interaction between an actuator delivering motion and a larger, static fixture.
- Pressure sensing, which is an indirect method of measuring the interaction between the actuator and load. In both force and pressure sensing scenarios, the repetitive shock damage of both the actuator and the load machinery is reduced by stopping motion before hard stop limits are reached.
For each input, sampling is performed at a rate of 4000 samples per second, yielding extremely fast responses to system changes, allowing high-speed hydraulic systems.
Parker PACHC motion module for 1-2 hydraulic axes. Image used courtesy of Parker
Analog outputs are also available for this motion axis module, also in both voltage and current modes, useful for providing signals to local machines when extended Fieldbus capability is not available.
PACIO Input/Output Modules
The PAC system also includes a series of I/O expansion modules for a wider range of configurations. Integration into one single system reduces the network infrastructure typically required when mixing both a control I/O system with hydraulic motion control axes. Instead of two separate module systems, they are integrated into one chassis.
The typical I/O arrangements are available with multiple quantities of digital and analog input, output, and combination. Temperature sensor-specific input modules are also available.
Included in the I/O modules are bus adapters for extended integration into other Fieldbus EtherCAT and PROFIBUS networks. Additionally, a high-speed counter module is available for encoder connections, which are necessary for many linear sensing applications.
Summary
Linear motion control is a complex, but fascinating application of control systems. The blend of electrical and hydraulic capabilities produces a speed and precision remarkably difficult for either system working alone.
Advancements in processing power and fluid control valves will continue to allow faster cycle times with better product control, and we’re excited to see how products such as the Parker Hannifin PAC series motion controller will be integrated into bigger, better, exciting machines.
