Third Dimension Noncontact Gauging Solution Now Available for Fanuc Cobots
Fanuc's CRX collaborative robots can now be integrated with Third Dimension's peripheral device, Vectro2, a plug-and-play noncontact gauging solution for metrology and process control.
Third Dimension, a company that specializes in delivering innovative metrology solutions, now offers a peripheral device for Fanuc’s series of CRX collaborative robots. The product, Vectro2, is an End of Arm Tool (EOAT) designed for Fanuc’s CRX cobots. The solution gives users the ability to automate metrology and process control operations for 2D profile measurements and quality assurance.
The Vectro2 from Third Dimension is the latest addition to Fanuc’s CRX collaborative robot devices. Image used courtesy of Third Dimension
Vectro2 Noncontact Gauging Solution
Third Dimension’s Vectro2 noncontact gauging solution is capable of measuring a multitude of different surfaces, including gap and flush, edge, radius, chamfer, angle, and other less common scenarios. The noncontact gauge opens up new possibilities for manufacturers looking for an easy-to-integrate solution for automated metrology solutions. The system works as an ideal tool for Fanuc’s CRX series of collaborative robots.
For an intuitive user experience, users can integrate Vectro2 functionality into a teach pendant tablet. The initial programming of the Vectro2 was designed for simplicity so users can drag and drop commands directly from the teach pendant when programming. In the teach pendant screen, users move the ‘Measure’ icon into the program timeline. After adding the measure icon to the timeline, a dropdown list can be consulted to select the desired tool.
The Vectro2 can be used as a robotic metrology solution to inspect different manufactured products. Image used courtesy of Third Dimension
Robotic Inspection and Measurement
Quality control and product inspection are a common source of error in manufacturing processes. Missed problem products can lead to expensive issues downstream, resulting in expensive warranty calls or costly product reworking. Third Dimension looks to help reduce or eliminate this problem with the Vectro2.
The Vectro2 is designed to provide users with repeatable and traceable quality control, helping to eliminate costly errors in the quality control department for 2D applications. Robots' repeatability and reliability for quality inspection processes should help manufacturers better inspect welds, adhesive beads, panel gaps, edge breaks, and more. The addition of automated quality control also manages to free up skilled labor for more useful, less tedious tasks around the manufacturing environment.
The Vectro2 solution is part of Fanuc-approved devices for the company's CRX cobots. Image used courtesy of Fanuc
Fanuc CRX Devices
Fanuc CRX Devices are a series of devices designed for use with Fanuc collaborative robots. Easy integration with Fanuc robots helps users simplify automation integration into their plant processes. The Vectro2 gauging device from Third Dimension is one of several solutions that make up the Fanuc CRX lineup of approved devices.
