Turck Releases Next-generation Flow Sensors With Alphanumeric Display
Turck has released its next-generation FS+ compact flow sensor series with IO-Link. The new sensors are equipped with an alphanumeric display to clearly show the flow and temperature of liquids.
Sensing and automation solutions provider Turck has announced its latest innovation in flow sensor technology: the next-generation FS+ flow sensors. The new series boasts an alphanumeric display for a clear indication of process data at the source of measurement.
A new generation of FS+ flow sensors: the FS101 with an alphanumeric display. Image used courtesy of Turck
Next-generation FS101 Flow Sensors
The new FS101 flow sensor series offers flow monitoring via an alphanumeric display. The display provides essential flow rate monitoring data and measurements in a 4-digit 12-segment display that can be rotated 180 degrees. This display is an update to the FS100 flow sensor series, which displays process values using a bar graph.
Additionally, the versatility of Turck's sensor series is increased with an immersion depth range of 16.9 mm to 64.9 mm in sensing applications that need insertions. The sensors are equipped with a screw-in adapter, with available G 1/2-inch, G 1/4-inch, and NPT 1/2-inch male threaded process connections, and feature an M12 x 1 male connector for electrical connection.
The FS101 flow sensors can monitor the flow and temperature of liquids across various applications. Image used courtesy of Turck
Robust and Reliable Sensing
Available with NPN/PNP (NO/NC) or 4-20 mA output functions and IO-Link, Turck’s new FS101 sensor series can communicate with a range of control systems. For durability and to withstand harsh industrial environments, the sensors feature IP66, IP67, and IP69K protection ratings and a stainless steel housing that protects electronic components as they come into contact with liquid medium.
The new series’ durable design, versatile adjustment capabilities, and high accuracy make it applicable in a range of industries, such as machining processes and welding, where it can monitor the flow of coolant. The sensor can also be used in applications like fluid level control and process verification in wastewater treatment.
The FS101 flow sensors clearly display process values, opposed to FS100 sensors that use a bar graph display. Image used courtesy of Turck
Flow Monitoring and Measurement
Flow rate monitoring and measurement are essential aspects to consider when accuracy is needed on a flowing medium. As flow sensing technology continues improving, engineers seek solutions that work best for their applications. Features like the alphanumeric display that comes with Turck's new line of flow sensors make the FS101 series an ideal choice for those seeking accurate, easily indicatable monitoring capabilities in their sensing applications.
