Volume
Control Systems
Chapter
Discrete Control System Elements
PDF Version
On/off Shut-off Valves
An on/off valve is the fluid equivalent of an electrical switch: a device that either allows unimpeded flow or acts to prevent flow altogether. These valves are often used for routing process fluid to different locations, starting and stopping batch processes, and engaging automated safety (shutdown) functions.
Valve styles commonly used for on/off service include ball, plug, butterfly (or disk), gate, and the globe. Large on/off valves are generally of such a design that the full-open position provides a nearly unimpeded path for fluid to travel through. Ball, plug, and gate valves provide just this characteristic:
A series of photographs showing a cut-away ball valve (hand-actuated) in three different positions reveals the inner workings common to all ball valve mechanisms:
cut-away ball valve cut-away ball valve cut-away ball valve
The left-hand image shows the valve in the shut position, with the bore axis facing the viewer (preventing fluid flow). The right-hand image shows the valve in the open position, with the bore axis perpendicular to view and allowing flow. The middle image shows the valve in a partially open condition.
